benny3
Flashoholic!!
- Sep 2, 2011
- 2,222
- 40
- 0
HOLY Recovery Image BATBENNY3!I think we DID it PiizaDude! I'm so SO sorry my ignorance caused so much trouble. It never looked like it worked, but I THINK maybe it did. I did as you said, took the PG86IMG.zip off the SD card, booted into fastboot and it still does the scrolling thing, and says no image or wrong image (I guess it can't decide which and wants to cover all the bases). But I did select Recovery, I get the TeamWin logo and choices of install zip, Nandroid menu, wipe menu, advanced menu, mount menu, USB storage toggle, Reboot system now and Power down. I'm pretty sure from reading I need to do a nandroid back up, so I picked that (it still gives an infuriating message toward the lower part of the screen E:Bad boot message "TIME") perhaps it just telling me it knows it's giving me a bad time. I chose system, data & boot to be backed up (the default choices). AND it DID it! Backed up to my SD card! I have just done my first nandroid back up! So I now have a unlocked, S-OFF, nandroid backed up EVO 3D. Benny3, I'm downloading the ROM now! This phone is getting perilously close to being activated! Thank you both SO much! So after I get the custom ROM on, will I be able to delete any apps I don't want? Although it sounds like you already took a bunch of them out Benny3. 69%, COME ON KGET, download that thing!
theres not much more you will need to delete , if anything you might want to add a couple back...lol, Does the time in recovery showing the correct time? if not go to advance and i think you can set it there
Come check us out over HERE
