What is your battery temperature?
PcNy
111
Hello,
What is your Nexus 4 battery temperature? Mine is around 32C while idle and may go up to 37C while using it.
SS: Idle, Everything stock
Is my battery too hot? Does the battery temperature increase according to the ambient temperature?
I'm living in a tropical country where the temperature is around 32C at days and 27C at nights.
And what are your battery temperature?
Thanks.
Right now it's at room temperature, 73?. The hottest I've seen is turned on, in the sun, in my car mount at 115?.
Using the phone a bit and installing CPU-Z, it went up to 26?C. And my max in Celsius (that I've ever seen) would then be 46?C.
Depends on room temperature. At idle it can be anything between 20 (winter) to 30 (summer) degrees. Max ive seen it while using it is around 37 while playing games
