What launcher are you guys using?
I'm using LPP mainly cause I just need 3 screens but probably will use stock launcher some too
I'm still swapping back and forth between stock and LPP. I'm not sure what's making me stick with stock other than its stock and pure UI and all. LPP has the scrollable dock, more rows/screen, no google search bar stuck at the top. Come to think of it, I'm not sure what stock has over LPP that I would need.
And yea, OP should have made this a poll.
Stock all the way. I have LauncherPro and ADWs paid Versions, love Go also, but the Stock browser is doing it for me :)
I would prefer GO Launcher to stock if it worked correctly, but I switched back to stock for now. I liked that in GO I could utilize the space in the search bar area, I liked the "menu" button that it adds to the bottom of the homescreen. I also like how you can longpress on the home screen to add widgets/shortcuts and it gives you the option to add several application shortcuts to the homescreen at once.
GO was working fine at first, but then the preferences screen stopped working. It will open for a split second and then it just goes back to the homescreen. There's no point in a launcher if the launcher settings are inaccessible so I'm back to stock for now. As soon as there's a fix, I'm going back to GO.
Totally stock. I like the fact that ICS is different enough that it's making me think my entire configuration. It really feels so much more like a completely new phone.
I'm using the stock launcher. The only things I really used Launcher Pro Plus for was resizable widgets and messaging widget, etc. Resizable widgets is now stock, and I can do without the other features lol
knightrider85
