has anyone found that screens that do not have a cut out over the light sensor causes any problems?
Switched to the wet install plastic Zagg yesterday. I'm a fan now. Ordered some IQ Wet install films from Amazon.
For me, I want a proper fitting protector and I've not come across a tgsp yet that meets that requirement due to the Halo effect because the edges don't stick. This IQ Shield is flawlessly installed and you can't even tell it's there.Is there a reason why a wet shield screen protector is preferred over tempered glass?
I'm just curious since I always thought tempered was the way to go.
They have both been just fine. The only reason I took the Zagg off was because I had another option in my IQ Shield to get rid of the specks that the guy from Best buy got under the protector. As far as value goes, you could buy 3 packs (6 screen protectors) of IQ Shield for what one Zagg costs. The only reason I bought it was because I didn't want to be out in the wild without a protector on my new device last Saturday!@mumfoau - which do you like better, the Zagg or the IQ? I have the Shinomi now, and though I installed it just fine, I feel it hasn't been as responsive, so I'm looking at alternatives.
Spigen Liquid glass. So far so good.
has anyone purchased the Power support tempered glass screen protector from the google store? i am waiting for my store credit and was going to use part of it on this (currently have a spigen case on it already). Thoughts on the tempered glass product ?
I do, I tried other screen protectors and none are close to the PS, it's expensive but it worth every penny! Highly recommend it!
Do the power support ones work with a case that has a bumper?
