What's the battery life on this?
I would say if you plan to use it for an entire day, you will need a charging source (laptop, wall outlet, etc) near by.
This is after 0.5 a day of use. (Had WiFi on, Browsing for most of the time, trying to get use to the keyboard).
I have a charger everywhere I go, and charge it at least twice a day. I do use it a lot more than I used my bold 9700 because of the browser, and all the apps.
I'm starting to realise that those claiming 15hrs on one charge barely use their Nexus...
I posted this on another thread but I am getting almost double the battery life out of mine after doing the following:
- downloaded advanced task killer and use it to frequently close apps
- cleared the cache of apps as mentioned in another thread.
- use the toggle widget to turn off BT, WiFi, GPS when not in use
- turned OFF auto brightness and set the display to 0 (or use the toggle widget for the lowest setting) - at night this is fine. During the day I use the 2nd setting (which is like 25% when you view it through the slide bar)
- only do push with my Gmail account. For the Exchange account I pull email and do not synch calendar or contacts. I use a desktop app for that between Exchange and Gmail
Before I was getting nervous about battery around 3-4pm. Now I am making it until 10 at night with more than 1/2 a battery left. For instance, it's 2:30, I've had about 10 calls so far today, checked my email a bunch and the battery is still at 65% - (not quite on par with what I said above but it's been a busy day).
i use it enough but i'm always on edge..
I don't have any problem using it from 15~16 hrs and still have 20% left at the end of the day.
I'm not on the stock ROM but I am pretty much getting the equivelent of what I used to get with my Moto Droid and a little better than my iPhone 3GS. I can easily make it through a work day with a good amount use. Usually when I get home I am around 30-40%.
I'm getting 12-14 hours of full average usage with phone/apps/video.
Got an extra battery and I've fully cycled charged them. On the second charge, it took only 2.5 hours to fully charge from totally discharged.
Dreamz
