What's the fastest way to drain a battery?
smooth4lyfe
Trusted Member
Sep 16, 2012
5,534
I have a 4500mah battery and I want to do a full cycle but the battery is draining so slow! (Which I known is a great thing but I want to do a full cycle)
Any suggestions on how to drain it faster?
I have turned off JD, put it at 100% brightness and watched a whole movie on YouTube and it's hardly going down lol
I probably shouldn't be complaining about this lol
Sent from my Samsung Galaxy S3 Boyyyyyy!
Play some heavy graphics games like Mc3 or NFS most wanted. That'll bring it down a good +50% in 2 or 3 hrs. :)
My one x is better then your one x!!
D:
Where did u buy the battery and how much? Did u need to modify the phone? I
Thnx...
Sent from my SPH-L710 using Tapatalk 2
Disable all power saver settings and turn all your radios on (Bluetooth & GPS), and if possible leave WiFi off and just use your data connection. And like what Sense said, play some graphic intensive games.
Sent from the cockpit of Gurren Lagann
Thnx...
Got a 4500mah Gorilla Gadgets battery from gorrilagadgets.Com
It comes with a bigger battery cover
This guy is crazy. You're backwards lmao. Most ppl want their battery to last longer and he wants it to drain faster. Hope this works out for you man
Lol I know right...I just want to do a full cycle
Im watching a 30 min show on YouTube brightness at 100 Wifi on and Bluetooth on lol hope this can get it down quickly
try not 2 use wifi. i think the actual data connection will drain faster than wifi.
Open navigation. It'll die in no time.
Also try to get bad signal that drains your phone super quick. So idk maybe put it in a drawer?
They make apps to drain battery as well. I think. Lol
Yeah especially with LTE, my battery used to drain fast as heck like that....I will try that as well
Yeah, I dont have unlimited data thats why Im tempted not to
Ah yeah this is what I was going to test. When I want to full cycle i let Netflix run on the data network.. Helps to kill the battery.
Wifi may work but not as fast.
Sent from my Sprint S3 using AC forums
what if my phone is stuck in boot loop and i cant enter the launcher screen or recovery mode. How would i drain the battery faster
You can't. Just keep the screen on and wait, hopefully you'll only need a straight day or two. Alternatively, remove the battery altogether.
Uploadmaster
