What's your home screen look like?
Is there any setting in Nova which allows you to have different icons for homescreen, drawer and folders ? I have a number of icon packs in my library but since I prefer stock icons in the drawer I hardly use my icon packs. Do you change your homescreen icons individually to icons from your icon packs ? I never feel up to changing them all individually .
I have never seen that option in nova. Just choosing a pack for global change of icons.
You can change them individually. Long press on the icon then select either Edit Icon or the pencil in the top right corner. From there, hit the icon then select your icon pack you wish to choose from.
In Nova's setting, go to Look & feel. From there select Icon style. You can remain stock in the app draw in this setting if you wish. Also, this setting will not affect any individually changed icon.
Screenshot_20200924-073320_Nova%20Launcher.jpegScreenshot_20200924-073326_Nova%20Launcher.jpegScreenshot_20200924-073330_Nova%20Launcher.jpegScreenshot_20200924-073602_Nova%20Launcher.jpeg
You can only apply one icon pack as a whole and then edit what you want individually. There's a catch, applying another icon pack in the future will give you some problems with the icons that you edited manually.
Thank you.
The individual editing option is nice .
There's a setting in Nova Settings > Look and Feel > Icon style > 3 dots > Reset custom icons .
I found this setting helps in case I edit individual icons manually. But it's a long time since I used this setting as I haven't used icon packs in between.
Thank you.
That only helps in the app drawer.
Thanks for confirming :)
That's the way I did it previously. I was wondering whether I missed any setting for separate icons in the drawer , home screen and folder.
I have sent in a feature request for this to the developers.
Sunday change up..
liquidsnake757
