What's your home screen look like?
Would be great if they looked anything like this, since there's only 2 folders I'll know what's in them.
Let us know if you have any problem changing those icons individually.
I never apply a whole icon pack and now I'm actually using three different packs at the same time. One for the home screen icons, another one for the icons inside the folders and stock for the drawer. :)
Long press the folder icon, edit, tap the icon on that popup window, select 7 Null from the list, scroll all the way down and they are under 'System'.
Thanks very much for your help, I never knew that the icons could be changed. Very happy now...
Hi,
Inspired by this I [...] and these don't adapt. Any idea if this can be changed?
You could the remaining change by hand. Beauty of Nova. Long click icon and click on the displayed thumbnail of the icon of that app to change it
should have read further down, I am way too late so therefore NVM
Can make up tho for it with my latest stock Xiaomi Launcher experiences
(I tend to play a lot with wallpapers again on stock dunno why xx)
First is lock screen
Second is overview of the layout
Rest of the attaches are the Home
Galaxy S10. Current.
Yes that one. Want to try it as folder icon. No idea on how to do that on non rooted devices and no pc.
You don't need root or PC. It's a normal icon and you can apply it using the same steps I mentioned before.
You don't ne...
I want to use it as custom folder icon.
I can't just change the icon of the folder somehow. I if I do that it doesn't show the preview of the content of that folder
I think I need to import that icon through Nova
That's the way it works. If you change a folder icon individually it won't show the shortcuts inside, that's normal.
Argh you drive me @#$&_
Nah just kidding.
I mean the following
https://gyazo.com/972c45242df0d4cd5033386b583fa957
There you can import that blank 7null icon to Nova. That way the preview works.
Therefore would be nice if you could link me on how to extract that icon if possible without root
Tysm
Sending gyazo link cause upload to tapatalk failed.
suuu
