- Feb 15, 2012
- 442
- 0
- 0
...Do you trigger HTC knowing your device has been rooted and have the warranty voided?
How do you revert to stock non-rooted condition?
thanks
thanks
If you want it to go back to a state of "HTC will never know I messed with it", then you must first get s-off. Only then will you be able to remove the tampered flag and change the pink bootloader banner back to "locked". After that, you should "Full Unroot" option within superuser and then flash stock recovery. Are you looking to do this now? And as for your first question, I think they know how to figure out who has unlocked their bootloader, so as long as you have the bootloader screen in order and it's completely stock(firmware, recovery and system Rom). I think you will be fine sending it in....Do you trigger HTC knowing your device has been rooted and have the warranty voided?
thanks
I'm getting an unlocked version.When you unlocked the bootloader you voided the warranty and HTC will know
Gottcha, But are you getting the Dev Edition or the model thats carrier unlocked?I'm getting an unlocked version.
Yeah- Dev Edition- should be arriving today.
I know you have to root first and then S-OFF.
But how does S-OFF help if rooting triggers HTC that it's been rooted?
