- Jun 8, 2010
- 114
- 4
- 0
Recently I installed SS Launcher in conjunction with the same developer's Popup Widget app.
I configured Popup Widget to popup the "Power" widget that is baked into the JB OS. That worked fine.
I ended up uninstalling both SS Launcher and Popup Widget, now my Power widget is gone from the list of available widgets. I tried restarting the device and had no luck. I reinstalled Popup Widget and tried to look for the widget from there, also no luck.
Any ideas how to get it back without a full wipe? I use my Power Widget constantly...
