Which Lock Screen Do You Use?
Nope .my battery is good .not drained anything .you can adjust volume when you listen music.you can try for free or buy premium.i use it for long time this and this is the best.
I just tried it out and didn't like it. Well, I'd love it if it worked properly. I have my phone set to swipe to unlock and it kept showing the stock lock screen for a split second and then showing the slide lock screen. I then disabled swipe to unlock from the stock settings and then it wasn't locking every time. This is unacceptable for me so I deleted it. I love the way it looks though and if it worked right, I'd definitely use it. I've found that all the replacement lock screens I've used are the same glitchy mess.
I didn't download an app, I downloaded a specialized apk file that I bought from tesla coil.
Has anyone found one they really like? I am trying to find one that will let you customize your icons too (not stock, but other). Go Locker seems OK but I quickly moved back to stock.
Sent from my SM-G900V using Tapatalk
Is there a Locker that lets you change your icons?
wobblefix
