Which other samsung phones use same battery as galaxy alpha?
jamessydney
Hi
Would anyone know if there are other samsung phones that use the same battery as galaxy alpha? The battery code is EB-BG850BBE.
Reason being my charging port has been corroded. It's not worth fixing etc but I want to be able to charge the battery and I've noticed there are USB Battery Chargers that you can put a battery in and it will charge..
I just want to get back on the phone for 10 mins and these chargers are cheap.. cheaper then buying a battery that would also allow me to get on the phone for 10 mins but yeah..
I search ebay for this usb charger and there are 0 for galaxy alpha in my Australia. but for many other samsung phones there are a lot.. that's why I wondering if anyone knew if this battery is compatible with other phones so I can search usb charger for them and put this battery in.
Thanks
reneeakers25
