Which ROM are you guys using?
I have, but with that being said the ROMs I saw an improvement on have been running the Hydra Kernel with the undervolted stock speeds. I flashed back to the Stock ROM and added only the hydra kernel and I'm seeing the same life. Bottom line, the OS doesn't affect the battery life unless you are referring to the kernel.
Ok, so I finally got the Live Wallpapers to work on my phone. I'm using the latest JagerRom (1.7.4) and it still didn't have Live Wallpaper support. So I compared the /system/app files from the 1.6.2 and 1.7.4 to see the differences. The files that I had to push to my device through adb are:
LiveWallpapers.apk
LiveWallpapers.odex
LiveWallpapersPicker.apk
LiveWallpapersPicker.odex
MagicSmokeWallpapers.apk
MagicSmokeWallpapers.odex
I'm not positive whether the magicsmoke one was necessary or if it came with the livewallpapers.apk file but I pushed it just in case.
Qazme, thanks to you I figured out what else I needed. Also, in your previous post where you told me to see if I did in fact push the correct files to my device I couldn't get the list function to work. After some googling I realized that I needed to cd to the correct folder which was cd /system/app and then I needed to do a "ls -l" command. This is what listed the items for me.
Anyway, thanks for your help. And if anyone wants the Live Wallpapers files, I've got them zipped up and can send them to you. Just PM me.
Alright very nice dude. Glad you updated us, I'm sure will find this helpful.
If you get bored with Jager 1.7.4 you should try pmf v1.1 YASR. (Non sense incase that matters to you)
Where can I find it? I'm all over the non sense. Also, my friend has a droid and I was trying to show her how in the phone dialer, I can just type a name. Hers doesn't have that function. Is that a sense thing or an HTC thing? If I lose that I may have to stick with a rom that has some sense left on it.
Thanks for the info
Nevermind, I found the rom.
I've really liked this ROM so far, the only thing has been the live wallpapers. Thanks for posting this
Jackwills2567
