Whitestone dome glass screen protector
What cases are people using? Ringke Air-S is the only one not causing lifting. I have a Spigen Liquid Air and Caseology Vault but both have caused issues. The screen protector when installed aligned more to the top as I have more room at the bottom but the lifting is happening on the sides as well.
Any recommendations on how to trim cases to fit as otherwise the installation went great?
I was worried the less curved screen night cause issues when screen protectors and cases
I am using a Tech 21 pure clear on my S20 plus and it fits great with the dome glass. no issues lifting.
https://www.tech21.com/en_us/protection/samsung/galaxy-s20-plus?color=Clear
I also have a Schnail case and it works with the dome glass.
https://www.amazon.com/gp/product/B...ag=hawk-future-20&ascsubtag=UUacUvbUpU6755024
Love Whitestone. I have used it on every phone I’ve had for the last couple of years. I did not use it on my S10+ because it did not work with the in screen fingerprint reader. Wasted 100 bucks trying to get it to work. Did all the steps with the updated video from Whitestone and it did not work. So beware.
I am using the dome glass on my S20 plus an it works fine. I had issues on my S10 from day one. I think the placement of the sensor being a little higher up on the 20 plus helps. your finger is in a better position to get on the senor when you pick the phone up. Mine is working great.
Good to know. Thanks.
cinemacritic
