Whitestone dome glass screen protector
when I went to the site a pop up came up with a wheel to spin. You enter your email address and spin the wheel. I landed on 40% off. It only works one time per email address. You have 15 minutes to use the code they give you.
Ok. I'll try three more of my email addresses - only got 10% the first time.
ETA: Got 30% with the second email and that's good enough. Thanks.
Nice I ordered it awhile ago with the 15%. Got 30% on the wheel. So reordered to save 9.00 lol
I will have a no spin code for 20% tomorrow but if you can get more by spinning go for it
Just got an email that the Whitestone Dome screen protector for my S20 Ultra has been shipped. USPS tracking number provided in the email. Hoping to have it by the end of the week.
My s10+ screen has scratches all over it so I'm thinking of getting a Whitestone dome glass screen protector for the new ultra coming next week. If anyone has used one before please share your thoughts? And can it be used with a case?
I had it installed on my S10+ and eventually it cracked with a case on. Personally I would stick with the flexible protectors...even the stock Samsung version over the overpriced and fickle Dome protector.
I have an app to create burner email accounts so deleted all chrome dats and kept trying the page and spin wheel. Did it like 15 times so settled for 30%
I was looking at getting this but found cellhelmet for $30. My question, does it work ok with the fingerprint sensor?
I absolutely love the Whitestone Dome. I scratched my 9+ the first few days of having it. I bought the Dome and had it for about 2 years. Finally took it off and no scratches. This is coming from someone who constantly drops his phone at least once a day. I have mine ready to go once my S20 arrives.
Oh, do I suck at putting the Whitestone Dome on. Three tries, three fails. I get to practice again with my wife's new phone tonight and, if I'm able to make it work, I'll hopefully have another glue stick to try on my S20 another time.
let's talk about this. how are you failing? not aligning it correctly? glue spreading too much? did you follow the youtube video step by step? i'm asking because mine arrive tomorrow and i'm beginning to wonder if the whole process is worth it. i am very anal and can see myself messing this up too. when it's a pack of 3 film protectors, wasting 2 of 3 is no problem to get the 3rd perfectly. with this though...
I was extremely frustrated, but not at the product. It was clearly user error.
Watch the video several times. If you follow the instructions, which I am usually good at, it should not be a problem. Make sure your working on a level surface, found that the desk I was working on was not completely level, which caused the glue to move to one side. Make sure you pull the pin at the correct time or too much glue will go to the bottom. Make sure you wait 100 seconds without touching anything to make sure the glue fully disperses.
I did not ruin the glass protectors because I never tried to cure the glue. Once I realized the glue did not have complete coverage under the glass, I stopped. I just cleaned the glue off the glass protectors with soap and water.
My advice is to watch as many YouTube videos showing the installation process and go from there. The good news is you can get a replacement kit for $9.99.
What cases are people using? Ringke Air-S is the only one not causing lifting. I have a Spigen Liquid Air and Caseology Vault but both have caused issues. The screen protector when installed aligned more to the top as I have more room at the bottom but the lifting is happening on the sides as well.
Any recommendations on how to trim cases to fit as otherwise the installation went great?
BarishYadav
