Who has successfully done the data2ext?
If you're looking for more internal memory on your V, give this a try.I installed this a few days ago and everything is still running smoothly. I got a boost of about 60 megs on internal memory. Only drawback is that it replaces the LG boot screen with a Sprint boot screen and takes a little while longer to boot. It does not change any other boot animations.
Optimus V -- Dalvik cache to /cache
Setup your ext partition. Then flash this: [Script][A2SD]Darktremor 2.7.5.3 Beta 04 [N1] (01/29/2011) - xda-developers
Then use this app to manage what you want on there and off: [App] Link2SD - xda-developers
You don't have to use both. Either one will work, but the Darktremor A2SD transfers everything over and installs useful tools like ext2->ext3 and ext3->ext4. While Link2SD requires you to move items individually and can't format. It is a good combo. I use it on Rodimus.
I was under the impression that they wouldn't work together. Only one of either at a time, am I wrong? I'm sure I read it in the app description on xda
Sent from my VM670 using Tapatalk
This might be resurrecting an old thread, but did anyone ever locate an e2fsck binary for Android 2.2? I tried searching and found one that does not work though, it was for an older Android release I think.
If there is a binary out there, I'd love to find it.
Ephraim
