EMGSM
Trusted Member
- Apr 8, 2015
- 6,037
- 125
- 63
I think they're out now?
https://dbrand.com/shop/samsung-galaxy-s8-plus-skins?utm_mnsid=UUacUvbUpU5782084
Thanks. I just checked and it's supposed to be delivered today.
Not me after watching this video. According to SquareTrade, the S8 is the first phone they've tested that cracked on all 4 sides on the first drop.
https://www.youtube.com/watch?v=AkoZM83X_i4
Not completely naked here, using a Dbrand skin just like I did on my Note 5. I have a case for the phone, but will probably only put it on when I go hiking.
I just got one of those zagg at best buy and had them put it on. I made it from the store to home which is 2 miles and tore it off. I don't know if the girl didn't do it right or what but it looked like garbage. You could see lines all over it and the left edge already wasn't sticking. It's now in the trash. May go to a different store when they aren't so busy and try again.I'm currently going naked only to allow my zagg screen cover to dry. Gotta say it is a beautiful phone, but the case will be going back on before going to work tomorrow.
Nope! Nope! Nope! I've already dropped mine a couple times.
You have to give it a couple days for everything to dry. Mine has lines and bubbles, but they should go away. However one of the edges doesn't want to stick and there's a piece of dust right on the edge of the screen. I'll probably be heading back up there Wednesday to have them redo it. I spent the $8 so if they screwed it up they can try again.I just got one of those zagg at best buy and had them put it on. I made it from the store to home which is 2 miles and tore it off. I don't know if the girl didn't do it right or what but it looked like garbage. You could see lines all over it and the left edge already wasn't sticking. It's now in the trash. May go to a different store when they aren't so busy and try again.
Nah never go naked. I dropped my galazy note 5 and the back broke so badly on such a small crack. A phone cost 850 plus tax im good. Just get a minimal case. Once you break that back or front you will regret a case.
