Who's liking their new phone?
So how do i optimize it for my region
I'm not sure if you can optimize it for your region - though this isn't my area of expertise. I've contacted OnePlus customer support before - their live chat setup and connectivity is pretty instantaneous. I recommend trying there first, and asking a OnePlus rep your questions. If that does not work, this may be a query for your carrier.
Update on my OnePlus 9.
I absolutely love it. Took time but now i can't go back to the LG Velvet.
The call issue is just a problem when inside. I guess not the best service here in this area. I also noticed when i turn of the data it doesn't take so long to dial.
That's so awesome that you are loving your OnePlus 9! It could be that all of your connections are looking for a signal and so that would delay other connections like data and the like. It sounds like it's working for you though!
Me! Me! I'm liking it! *hopping excitedly from one foot to the other while raising my hand*
I've had this phone for 2 weeks now, came from a Huawei mate 9. This is my first one plus & so far it's just "OK".
Things I dig:
Fast battery charge
No lag / fast/ smooth
Things that are just ok:
Battery life
Mute switch - unusual option (although I think it's backwards - down is on?)
Things I don't dig:
Weather widget does not update to your location - only shows "home"
Volume button directly opposite of power button - I can't tell you how many screen shots I've already taken, turning the phone off.
Volume rocker controls media volume by default. With no apps running, the volume should control/change ringer volume.
Finger print sensor is too low.
No notification led.
I like the phone, but im 95% sure when iPhone 13 is out i switching to iPhone. Been with Android since the Samsung galaxy S vibrant. Time to make the switch.
That's pretty cool! Let us know when you make the switch and how you're liking your iPhone 13!
Scratch that idea. Almost pulled the trigger.
Ordered Pixel Stormy Black 256gig instead.
That would have been a tough decision to make between two excellent phones! So excited that you ordered the Pixel 6! Did you get the smaller version or the Pro version?
From a Pixel 3 (small one). Love everything about it. Especially battery life and smoothness. Screen is beautiful.
Don't like: OnePlus store notifications (can't find a way to turn them off). Miss wifi calling (I had a call and connection was bad (could have been better through wifi, I feel), That's about it!
johan mayhew
