Who's Running Battery Doctor?
OK old topic but one quick caveat with Clean Master and Battery Doctor (which the dealing with finally made me uninstall them and go with Greenify): you can put apps in the Ignore list, but sometimes you have to research to Ignore some system-type processes that can be Ignored that "feed" the apps. When I was using CM and BD, Waze would sometimes just die in the middle of a drive. Turned out that Waze dies if it doesn't see your phone having a working GPS in a timely manner. I had to figure out which "background" process to Ignore. And the interface makes that hard as it truncates longer names at a certain number of characters. I never did figure out what was causing my texts to be delayed by up to a half hour but that went away immediately after I uninstalled both (I tried several SMS apps and all had the same problem). I'm much happier with Greenify.
Battery Doctor is one of the most worthless, horrible, evil Apps ever written for Android. Anything by Cheetah Mobile is horribile.
To understand why Battery Doctor and other such apps are so bad go back in this thread and read posts # 3, 23, 27, 31, 33 & 180 - especially 180. http://androidforums.com/index.php?threads/896663/
Actuality, it's a good idea to read the entire thread. Lotsa excellent information.
Check this out too:
http://forums.androidcentral.com/showthread.php?p=4435166
Android since v1.0. Linux user since 2001.
Since i installed this app i cant ay music..wtf..anyone no how to fix.100% this app.was fine untill i got this crap ap
tryhomematch
