Why can't i turn on "Access with voice match"?
  • Start date Start date
A
Android Central Question
I go to the option on my Google app, and it literally turns right back off when I try to turn it on, by itself! It's really annoying.
I tried all the steps mentioned on this
But it works fine now
Lemme tell you how I did it
1) go to setting
2) go to Google app
3) force stop
4) go to storage clear cache and data
5) click on the 3 dots on the top right corner and uninstall updates
6) now hold home button to turn on assistant
7) set up everything and now u can turn on access with voice match
^_^ thank you
Hey, i have figured out a way to fix this.
• go to app store
• go to google and uninstall (it wont rly uninstall it ( i clicked update idk if that bit would work tho)
• go to google > more ( bottom right) > google assistant
• should ask you to say ok google and hey google to set up ur assistant.
Not sure if it will work for all of you but its worth a shot 😀
Hi everybody. Uunable to switch on "Access with voice match" ? Turns out that you must enable the 'web & app' and 'voice & audio' activities in your Google account. It's a toss up between features and big brother Selection_042.jpg
if the "use context on screen "and turning on google assistant does not work, try changing language both in assistant setup and in unit language so they match and try the abow again. For me it was a mix of both.
heritagevine18
