Why does my Note Edge battery drain really quick?
  • Start date Start date
A
AC Question
Note Edge Battery draining really quick !!!!
Got this note edge of At&t and the battery drains really quickly ! 5% in 10 minutes ! Changed the battery didnt work!!
got the software installed again didnt work!!
got the phone check if any hardware problem but no problem !!
I dont know whats left to do :/
Welcome to AC.
Use it normally, then when you need to recharge, take a screenshot of your battery usage stats. Post that here if you can. If not, tell us what it says. Tell us also what your signal strength is, and whether your basic settings for sync, location, etc., are battery-friendly. Then we'll try to diagnose. :)
Re: Note Edge Battery draining really quick !!!!
signal strength is consistent getting 4g but even if i switch off mobile data plan it just drains while using the screen even though my brightness is really low ! Even when writing this my battery has dropped 2 percent
Screen 47%
Android System 22%
Estherlampard
