Why does my phone keep disconnecting itself from my wifi?
Emily Moore1
My phone keeps disconnecting itself from my wifi.
So since yesterday my phone has will not connect to mine or any wifi network. If i turn it off then back on again it'll connect for like 30 seconds then disconnect then it wont connect back again. I've already restarted the router its not that. I don't know what else to do I've already tried the advanced wifi options and nothing seems to work.
Re: My phone keeps disconnecting itself from my wifi.
1. forget all wifi networks.
2. change wifi password to something with no special characters.
3. change wifi router channels and encryption.
4. hard reset phone if all else fails. back up your data first.
good luck.
TheGreatApe00
