Why does my S6 audio streaming Stops/Starts randomly?
Ken98045
5
S6 Audio Streaming Stops/Starts Randomly
I've been having the same problem with 3 different audiobook players on the S6. These include Overdrive, Audible, and Smart Audiobook Player. All 3 behave identically. Tech support for Overdrive and Audible are at a loss.
First, audio pauses randomly over a period of 5 minutes to 1 hour. Second, the audio paused by this bug and/or manually paused will magically start playing over a period of 1 hour to 8 hours. This is very annoying when it happens at 3:00am.
I wiped my phone and reinstalled from a backup. Things worked fine for a few days. The problem then came back.
I got a new phone from Verizon warranty. For the first 4 weeks things worked fine. Then, suddenly the problem came back. I wiped the phone. The problem went away (I think - it's only been a day).
Anyone having similar problems? I can't see wiping my phone once every week or two indefinitely.
Re: S6 Audio Streaming Stops/Starts Randomly
If you're talking about over Bluetooth, I have the same problem. I also had that problem with my S5. Haven't been able to find a solution. It's VERY annoying and I wish Samsung would fix it. It happens with music too. Maybe the next update will fix it, but I doubt it.
Do you happen to have the Comcast xfinity connect app installed? It did the same thing to my s6. Uninstalled and issue gone. The app has a voip feature that was probably interfering somehow.
I do have that installed, and now that I think about it, I started having the problem again shortly after setting the app back up. It's been installed since I got the phone but I hadn't logged back in. I'll try that. Thanks man!
You're welcome! It drove me nuts! Tweeted Comcast about it and they didn't respond. Typical! Hope the fix works for you too!
I have the exact same issue ... I reported it here about a month ago.. I also have the COMCAST App installed ... I'll send a bug report to COMCAST from Google Play. Thanks for identifying that as the probable culprit. This had been driving me nuts. It is so unpredictable whether music or a podcast plays without STOPPING
update: In my case, it is not just streaming, but just playing music or podcasts that have been loaded into my phone.
That fix worked. I'm so happy to be rid of that problem. They need to fix that. Guess I'll submit a bug report too
Yup, I had the Comcast app installed too. I hope that does it.
I'm having the same problem, and have tried restoring the phone, but the problem returns. As a consequence, I find myself using my iPad pro more for streaming music than I care to. I think, even though I really like this phone, I may return it to my carrier and get another note 5.
Don't have the comcast app, but still having this problem with my xm, and any podcasts.. any other thoughts on what I can do to fix it??
Regarding all kinds of streaming problems and also GPS activity tracking problems, such as with RunKeeper or Runtastic, simply disable power saving mode or set activation threshold to a lower battery % and your problems should go away. Those problems started to me after Android Marshmallow update. I hope it will help.
I have an S6 active that just got the Marshmallow update and to the best of my knowledge, that is when my problems started. I don't have Power Savings mode turned on so I don't think that is the issue. AT&T issues an update this morning, but that doesn't seem to have solved it either. I have XFINITY apps installed, but don't have XFINITY Connect installed. Should I uninstall the other XFINITY apps? Any other suggestions?
I had the same problem. Mine would be about every minute and a half. And would restart randomly. Immediately app uninstalling the Xfinity Connect app. The audiobook resumed playing. thank you.
Hi everyone,
Try this:
  • Settings
  • Device Maintenance
  • Battery
  • Scroll down to "Whitout Supervision"
  • Add Application
  • Select the app with problems
  • Done
The names above could vary because I've them in another language. The idea is to tell the the software to not "optimize" those specific apps.
