Why is Blink feed still using Most*battery after turned off?
So you guys are wrong, i have my HTC one M8 for 4 days now and i was also wondering why blinkfeed was still using power even if "disabled". You say it is part of the launcher (i'm resuming) and that it has to be running. That's not the case, because when i see that blinkfeed used power, i can then KILL the process, without loosing anything in my Launcher (nothing changes but yes it reloads), and when i'll check later, it will not appear in the process that used a lot of battery. How can you explain that ? why is killing it stopping that heavy usage and putting it back into a normal state and what could be done about it ? I'm of course rooted and on ViperOne M8.
They aren't wrong. Most suggestions are to use another Launcher or root to disable (like you did).... So not sure where you're coming from.
Sent from my T-Mobile Note 3 using AC Forums.
ahsokacat
