Why is my battery draining so quickly on my GALAXY S5?
Re: Suspicious battery drain on GALAXY S5
So i tried to switch system android (in service). Now I´m on 4.4 and the battery life is even worse! Look
Dont be so quick ? i tought i had the same problem but no.
I bought the phone before 7 days , the phone itself had a 5.0 lollipop update which is little strange .. ( i tought i should update by myself )
I tought the same as you battery drain ...i downgraded successfuly to 4.4 kitkat
You know what ? i tought still have the problem , but when i went to someone with the same phone he said to me it's ok relax , thats the battery life , you are moderate user your phone will last day and half.. its extra
Heavy users that stays on their phone gets a 10 hours of usage and they need to charge......
If your phone is 5-6 months , you dont have problem .... you just imaginate like i did....
Go buy 3500mah official geniune samsung battery .... it's very useful it's about (43$) which give you 700mah plus to your 2800mah battery. (i plan to take too)
For example: if you use your phone for a day and half, you'll probably use it for a 2 days , or 2 days and half without problem (if you are moderate user)
Free up some space. When there is too little free space the cpu works harder swapping everything around.
Dave cat
