Why is my battery draining so quickly?
Try it yourself - put the phone in Airplane mode for an hour, then take a look at the History details screen.
Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk
Ok I'll try it this weekend.
Re: Why is my battery of Samsung mobile no. GT-S5303 draining so quickly?
Battery of my Samsung moblie no. GT-S5303 drain very quickly I have to recharge it 4 times a day. Pl. write me the solution prctically. I am fed up with this piece. Pl. help.
Welcome to the forums!
Given the scant information that you've provided I doubt that anyone could suggest a solution. What you can do is:
- read all of the posts in this thread for any suggestions or links to other helpful threads
- post the three screenshots mentioned in other posts/threads
Had the same problem and did some tests. For me the battery drain was caused mostly by different apps running in the background and updating via my wireless connection (not WiFi). The emails are actually a large part of this and it is difficult to switch this off (have changed the settings for updating my mail).
Did other things too (screen brightness, closing apps, etc.) but the mobile data was the worst by far.
Finally, if your phone is old (over 2 years) you may consider changing the battery and/or doing a restore to factory settings to remove clutter.
Halp
My battery will occasionally drain two percent(at the same time) every three seconds until it dies or I get it to my charger. Also my phone will restart randomly without my input, it happens whether I'm using it or its just chillin on the table.
How do I add pictures again?
andiox
