Why is my phone asking me to enter a privacy protection password to unlock?
Status
Not open for further replies.
Hi! Thanks for your help. I finally unlocked my phone. When I turned on the anti theft it asked me to add emergency contacts.
There are three commands that you can send to your phone (from your emergency contacts cell phones). One of the commands sends you back a new privacy protection password to unlock your phone. In my case the command was #mima# (with hashtags). I sent that word from my husband's phone and I received a message with a new code to unlock my cell phone. Once I did, I obviously changed the code and also you can turn the anti theft off so you dont have the problem any more.
Good luck!
This helped a friend of mine unlock her phone. Thanks.
my tecno phantom z-mini is asking for my privacy protection password, please help me on how to get my password
Re: enter privacy protection password to unlock
same problem with my "micromax canvas xpress 4g"
i registered my father's mobile number in anti-theft and forgot my pin......
My father received a message that your phone has stolen.....
I just replied to that message "#password#" (without quotes)
within few seconds I received a message containing a pin....:D
i just entered that pin and unlocked my phone....
It worked in my "Micromax Canvas Xpress 4G"
This method worked for me. I tried on my younger brother Blu Studio C HD (he was desperated) and it worked.
Thank you very much for your help.
i changed the sim card of my phone and after rebooting the device, it shows a lock page saying " please enter privacy protection password to unlock". this page don't have Google log in method even.
please help me out....
I have the same problem too with my phone Infinix X600
I've never remembered make any password to anti-thieft or else. It's suddenly happen when I tryin change my SIM card
I've tried factory mode method (clear eMMC also reboot) and send #mima# to locked phone, but nothing happen. It's still same. I can't unlock it, it always on 'please enter privacy protection password to unlock' screen
I am unable to use my phone due to this problem as I can only receive calls but I am unable to make calls .
my name is biswanil
i nuse a swipe elite phone. my phone is showing to give a privacy password to unlock. plz help me for unlocking it.
urgent
Sounds like the SIM card is password (PIN, rather... SIM cards aren't usually that smart) protected. Is the message appearing after the OS boots or before it does? If it's before, most likely your phone is not unlocked for other carrier's SIMs and you're trying to use one of those. If the prompt appears after the OS loads but before you can get into the phone, it's the SIM. Try removing the SIM and booting up without it. If the prompt goes away, there's a PIN protection on the card.
This.
Status
StevieD49
