A
Android Central Question
My Samsung Galaxy S7 stopped showing voicemail notifications and would not ring all the time. I took phone up to MetroPCS and they couldn't figure it out then told me I needed to get a new phone.
I then got with Samsung Tech support and they had me do a soft reset and put phone in safe mode to see if the issue was coming from 3rd party app. Those steps did not work so they told me to take phone into Samsung store to see if they can help.
Instead of doing that, I took my Memory card out and performed a hard reset. I then reinserted memory card and the hard reset solved the Voicemail Notification issue, but now I keep getting warning saying "memory dangerously low" - 31.2GB/32GB. I noticed it copied my memos multiple times (each recording was showing 10 copies) so I deleted all Samsung Memo Recordings which did nothing for the memory. Before the reset - my internal memory was around 20GB/32GB. I have uninstalled all my apps so only the pre-installed apps are on it, which lowered it from 31.7 to 31.2GB. Why would doing a reset mess up the memory and how can I fix this?
When I go into Device Maintenance and try to look at internal storage, there are several folders but there is nothing in most of them. Please help! I have been out of work since October so I do not have the money to get a new phone.
THANK YOU IN ADVANCE
