Why is my wifi disconnecting and why do I need to reboot for a temp fix?
  • Start date Start date
A
AC Question
WiFi disconnecting, need to reboot for temp fix
Last night my Droid Razr has decided to disconnect from my Wi-Fi and will not reconnect on it's own! I have to turn it off/on and even then it will only stay connected for 60 seconds or less! I do NOT have Bluetooth or Data turned on and have tried turning the phone off then back on with no success. Also reset my router. I have version 4.42. I have never had this problem until now and it's SO frustrating! Wi-Fi says it is connected but it's not! Please help with this problem! Thanks!
Re: Ok here is my question or problem! What's causing Wi-Fi to disconnect on my Motorola Razr?
Have you reset the router? If not, unplug it from the power source for a minute and plug it back in. When it boots back up then reconnect to it and see if that fixes your problem.
Yawder
