Why is the battery life on my Note 4 low?
Well I've turned off every bloat app that I can or that I don't use. Plus I use a black wall paper that I think helps. And I use auto brightness that works perfect for me. On the other hand I never use wifi and I always use blue tooth ear piece. Plus I'm running art. But I was getting great battery life before art.
No wifi helps what bloat apps u disabled
Re: Battery life on Note 4
Post a screen shot of the list of apps u have disabled in application management
Sent from my Galaxy Note 4
Holy bloat tmobile has almost none of those apps
Wow, 5+ hours of screen on time? I get 2h45 - 3h and then my battery is at 5%.. I'm really beginning to think something's wrong with my unit..
Im also experiencing low battery life for Note 4. I dont use the phone for sms and calls, i do very minimal browsing using mobile data. i play an online game for about 3 times per day, 10-20 mins more or less. I listen to music.. but i only get a screentime of maximum 3 hours. Is there somthing wrong with my device or the battery?
Thanks!
what activities do you normally do? do you use the power saving mode?
thanks!
No and it depends normally it lasts me 10-12 hrs of very heavy use im on instagram constantly and texting mostly and family guy and simpson games now and then. Sometimes some web browsing. And i use clean master to check cpu for any lagging apps and to boost cpu and the more i stay off the phone the more battery i get lol i get between 10-14 depending how heavy i use it
wish mine would have the same performance as yours. not sure if it's busted or something..
So many threads, so many answers. Apps like GSAM. Almost none of the phones are "busted".
Gsam didn't seem to add any information other than what's already available in the settings... Am I missing something?
Aruz530
