Why is the battery life on my Note 4 low?
Number of installs doesn't decide the quality of app, remember each app installs starts with 1-5 installs and then the installs grow over the period of time. None of the app installs come with 10k from the beginning. Please do not be judgemental without using any application in any case. You must respect the hard work developers put together to make users mobile experience better on day to day basis. Thanks.
This app answers multiple issues, junk cleaning, auto battery life optimisation and ram cleaner in just one touch. Install it, use it and then give your comment please. I am hopeful that it will solve battery issue of Note4 considerably as it has solved mine. Thanks.
I dont think anything else can be done for the Note 4. At launch I could get close to 6 hours screen time and now it doesnt matter what I do I'll get around 4 hours screen time. I have factory reset and I'm on a new battery. Installed apps are minimal and screen brightness is down to the minimum. Nothing out of the ordinary shows up on battery usage with screen being the highest user. I think software updates over the years have made the Note 4 use more batter its hardware cannot keep up.
Re: Battery life on Note 4
My battery problem turned out to be my SD card. Took it out now battery life is better and no over heating
pamatika
