Why isn't my Note8 continuously reconnecting to charger?
  • Start date Start date
A
Android Central Question
My brand new Note8, barely a week old, won't charge anymore with the brick. When connected, it just continuously reconnects and I can see the charging icon come and go and the beep sound continuously. I've tried different ports so the socket isn't the problem.
I'm using all the Oem accessories and fast cable charging has been disabled.( I don't use fast charging) Its been working fine for the past week and there has been no software updates ( I've read about others having the same problem once freshly updated to nougat, but nothing's been updated here) my only option to charge now is through the pc, which takes ages.
I also noticed now that the wireless charger doesn't seem to work. It flashes its leds, meaning it gets power, but the phone won't charge. I think it's a problem with the brick.
Any opinions on this?
Welcome to Android Central! First, make sure the charging port is clear of debris -- blow it out with a can of compressed air. If it's clear and the problem continues, then bring it to your wireless store or your local Best Buy's Samsung store, and ask to use their Note8 charger -- does the same thing happen?
It more likely is a bad cable, because you are having intermittent charging. Or it could be that the cable is not fully pushed into the charging block. Perhaps, it became loose.
Well I took it to Samsung repair center and they replaced both the adapter and cable. Its working now. I tried two sockets before and both didn't work. Even at the repair center it didn't work. Will have to see if the new one will run into any problems, and I will update. It'd just so weird for me since I've never experienced or even heard of accessories failing just after a week of very careful use.
iasolutions02
