WiFi calling in Quick Settings?
Can you , what's the command for that?
When i get home I'll look for it, that's how i added mobile data toggle since AT&T removed it as you see mobile data
Because it's unreliable for me, so I only want it on when absolutely necessary.
Oh, OK. I haven't used it much. I thought it would select whichever service was available. I have it on, always and see no issues. Thanks.
It does if you set it to do so, but the system just checks for connectivity, not for performance until you're actually IN a call. Some WiFi networks will act crapily with WiFi Calling or block it entirely (some hotels are starting to do that, for instance), so there might be places you know you're better off with WiFi Calling off. Another reason (if you don't use a VPN) is if you're in a network that you don't want to log you were using it for calls (work, public place, etc.).
Understood. Thanks, for the detailed info with examples!
I agree with your statement. I’m on T Mobile.
Thanks man for trying to help.
That's the culprit. T-Mobile's WiFi Calling and Visual Voicemail app have been bugging out for a couple months now. I think it started two security updates ago.
Really, you get the notifications, man Im lucky lol
When I pressed on the down arrow of the message it said "these notifications can't be turned off".
So, this is a losing battle, also reported on AT&T and Verizon.
agustuscrown
