I was having issues initially with my WiFi disconnecting frequently after the JB install until I found the following setting, and it's made all the difference. Go to Settings/WiFi
then hit menu and go to Advanced,
then un check Avoid poor connections.
Parts of my house bounce between 1-2 bars on WiFi, but I never lost connections before JB. I'm just glad changing the setting worked for me. Hope it helps others out too!
Sent from my DROID RAZR MAXX using Android Central Forums
