WiFi connection issues
pcabe5
258
4
Anyone else getting authentication issues when trying to connect to WiFi? The phone will not connect to my work WiFi. Rebooted router and the phone, verified settings and even deleted the network and still no go.
I've seen this type of behavior when the authentication is complex, like with WPA/WPA2 and a alphanumeric key with special chars and caps in it, .,e., Th@t1$OneFunkyEncryptionK3y
Some devices don't react well to having to use stronger keys.
I can connect to my home router just not work. I even tried an open and a WEP with no luck. Factory reset on the phone and the router with no luck. I think it is the Westell router. I'll try a new router tomorrow.
Sent from my HTC6500LVW using Tapatalk 4
Installed a router from home in my office a it works. Must be the Westell dsl modem is not compatible.
I found an issue when I did the password in small letters instead of all caps. How is the password defined? I too have had issues with non-alphabetic characters in passwords.
Well this doesn't bod well for me - as I'm going to get one of these tonight and our home DLS is a Westell. I hope it is not the modem, but something else!
The password was alphanumeric and lower case on the dsl westell router and I used the same password on my netgear router. All I know it works. I just use my netgear as an access point to the dsl. Since coverage sticks in my office without WiFi my phone will die and I needed a solution.
Yup, my new HTC One won't authenticate on our Westell Modem. Out to twitter I went and HTC was stumped as well, however, I'm going to get a router tomorrow and try that. Tech friend of mine said that is probably the issue because Westell is not a true router. So I'll let you know.
I like the phone and want to keep it so have to to figure out the WiFi issue.
New modem from AT&T and the phone connects like a champ. :D
Sent from my HTC One using AC Forums mobile app
I have also been having issues at work with my One connecting to the Wireless. I work at a hospital and have access to the secure network, but when I jump from access point to access point, it ever fully connects back. The key is a WPA/WPA2 with letters and numbers in it. I have not been able to figure out the issue. I also have an issue with my phone connecting to LTE. It mainly happens when I have left work and shows that it has connected to LTE, but I cannot access internet or anything that accesses the internet. It has been bugging out like this since the update from a few weeks ago.
kctraci1
