WiFi issues after rooting - Please Help - First time rooter
squane123
Active member
Oct 1, 2010
33
I finally took the plunge and decided to root the Charge. Everything looked good until I was unable to connect to my Home WiFi. It recognizes it, attempts to connect, says connecting then disconnects. I have terrible service inside my home so I rely on WiFi. Anyone else have this issue.
FYI- I used Odin3 v1.30 and used stockrootedED1-2011517.tar.md5
Probably not the newest and more than like that is the reason I am having issues. It was so simple and I was extremely paranoid.
I think your issue is that you went backwards flash the rooted ee4 din package and see what happens
Charged up post!
Thank you and I will gladly try that. Would you care to explain how. Haha. Will I go about this the same way that I just did using the Odin?
Hammyj
