WiFi issues at work
  • Start date Start date
A
Android Central Question
My Droid Turbo will not stay connected to our employee wireless network. None of my associates are having any issues and I do not encounter similar problems on my home network. I have deleted the network and reinstalled but to no avail. With no others having similar issues, talking IT into resetting routers is probably fruitless. Anything else I can try save a factory reset?
Welcome to Android Central! Does it initially connect, then drop the connection? Is it the kind of wi-fi network where you have to enter a wi-fi password (i.e., the wi-fi network has a little lock icon associated with it)? Or is it the kind where you have to enter your login credentials on a separate captive portal login webpage?
Ameedshamsan
