Will a Note 4 wallet case fit my Note 3 phone?
  • Start date Start date
A
AC Question
Will a note 4 wallet case fit my note 3 phone?
I ordered a 4 by mistake.
Re: Will a note 4 wallet case fit my note 3 phone?
The Note 3 is 5.95 x 3.12 x 0.33 in. The Note 4 is 6.04 x 3.09 x 0.33 in. It'll fit but you can probably slide a business card inside the case with the phone in it a little more easily. (The Note 4 is 0.09" longer and 0.03" wider - I don't think the case manufacturers hold to such tight specs, so the Note 3 case would probably fit the Note 4 also.) In any event, unless you tried shaking the phone out of the case I doubt you'd notice the difference. Maybe not even then.
Lelix2603
