- Apr 17, 2013
- 173
- 0
- 0
can't seem to find an answer, if the tmobile note 4 is unlocked of course
Nope, different carrier signal on the cell towers.
Correct, the Verizon Samsung Galaxy Note 4 will not work on tmobile and att(with limitations) , but not vice versa.This would apply to this case only because the T-Mobile Note 4 does not have CDMA radios in it.
Not sure what you mean. The Verizon Samsung Galaxy Note 4 has xlte support which is the same band class as T-Mobile's wideband lte capable of 150mbps where 20+20mhz xlte /wideband lte is deployed. Att also uses band 4 lte, albeit in limited deployment.The CDMA variants come with GSM radios so they can be used on LTE architecture...And (theoretically) so they can be used internationally (for vacations, work assignments, etc). So using a Verizon or Sprint variant on T-Mobile or AT&T mostly works. However, the carriers use different LTE bands (i.e. RF frequency ranges), so if you did try it, you would likely only have HSPA+ data, not LTE.
Note: LTE is a GSM technology...which is why Verizon and Sprint started using SIM cards over the last couple of years. This is why their phones are able to easily "speak GSM" these days. The SIM cards have nothing to do with their 2G/3G CDMA architecture. CDMA is dog slow, but it allows Verizon and Sprint to more tightly control access to their networks.
No. Can't work on another carrier. Period
