Will T-Mobile Nexus 6 ever get 6.0?
Not the reason. Most people that have a nexus 6 on t-mobile purchased it outside of t-mobile. As soon as you insert your SIM card in your nexus 6 it tells the network. So currently the n6 update is being held by t-mobile even though it comes from Google servers. Best way to get it is to remove SIM card, reset and connect to WiFi. Then the 6.0 update will come though, after that you can re insert your SIM card. The easiest way would be to use adb and sideload zip ota file.
That is why I said I think Google went away where it won't be "held up" for whatever reason. I still get updates on my 6P (like security patches) through T-Mobile and they don't block that so not sure why they would be doing it on the Nexus 6.
Re: T-mobile Nexus 6 6.0 Update
Meaning the one bought from a T-Mobile store that has T-Mobile WiFi calling baked in, so?
I wonder if illiterate people get the full effect of alphabet soup
T-Mobile Nexus 6 also had different software builds... So it is kinds specific to tmo correct me if I'm wrong.
That was my point, I'm glad you understood what my comment meant.
When a T-Mobile SIM is inserted in a 'standard' N6 it will download the T-Mobile software and is then exactly the same. There's no physical difference between N6's bought from Google and T-Mobile, not even a logo.
Well it ain't the 6.0 update, but I just got the 5.1.1. November OTA security update, build LYZ28N. I was actually more interested in that anyway, but it was nice to see any OTA making it past my T-Mobile SIM.
As I've now explained not once, not twice but thrice, T-Mobile nexus 6 will never get android 6.0 OTA.
Stop pining after something you cannot ever have and accept your doom.😉
You are obnoxious. How is this even remotely helpful to anyone???
Notice the winky face indicating that I'm joking? I'm just trying to lighten the mood while we wait.
Day 38 since Google 6.0 rollout began.
I went ahead and pulled my sim and factory reset my 6. The 6.0 OTA fell right in place. Done.
OTA to Android 6 from LYZ28N on T-Mobile??,
Has anyone seen a link to the OTA file for upgrading to Android 6.0 from LYZ28N? t-mobile tricked us into to installing this update last week and now it's not possible to sideload Android 6 on the Nexus 6 (only the LYZ28M sideload is available)! Pretty sneaky if you ask me!
Re: OTA to Android 6 from LYZ28N on T-Mobile??,
No, I think you're wrong. The article you refer to is for LYZ28M not "N". The zip for LYZ28M will not sideload on LYZ28N -- already tried it and it dies at 48%.
I had already allowed installation of the November security update (to LYZ28N). I removed the SIM, maintained connection to WiFi, and did a FDR. It didn't pull down the update, though - and it still showed LYZ28N.
According to https://developers.google.com/android/nexus/drivers, LYZ28N is a T-Mobile-only build, so even a FDR won't pull back that T-Mobile stamp.
Any other steps others have taken after having deployed LYZ28N that have allowed them to successfully update to 6.0?
Pull sim and reset using WiFi...6.0 should push to phone during reset...worked for me!
Any advice on how to get the ota from build lvy48i?. This was a tmobile phone from the store,,, then I did a warranty exchange and received a fi phone, tried three times and only kept getting a project fi phone build phone, which also screwed me out of tmobile WiFi calling, which I need. So since then I still use a tmobile chip /service but lost WiFi calling and haven't seen 6.0 yet. Any similar stories?
Exact same story for me. I did the Nov security update (thinking it must, at long last, be 6.0). When it wasn't I then tried the sim removal/factory reset trick which doesn't work (i.e., no OTA 6.0 update). As mentioned above I also tried to sideload the LYZ28M_to_Android 6.0.zip file that is widely available. It fails as well about 50% into the sideload process.
Uhh. I had 6 installed, just installed the latest security patch and it downgraded me back to 5.1.1?? LYZ26N.
W. T. F.
My T-Mobile stamp says LYZ28M. .?
If you're on LYZ28M, you should be able to sideload the update as there's one that is keyed for that version. If you accept the update, your only option is to flash the full stock image.
I put in a call to Google support on the matter. After the initial rep (who said that Google had no published information internally or externally regarding LYZ28N...) I spoke with a "Nexus Specialist" who said that FDR's do not roll back the OS updates, so my options were to contact T-Mobile re: a solution or to flash the original stock image (I've pasted the steps he gave below, for anyone interested).
Code:
Hey Jeremy,
My name is Carlos, It was great speaking to you on the phone today. As promised, I've included the steps below. Since each step is very important to the next step, please carefully read and complete each step one at a time.
Download the ‘SDK Tools Only’ zip for Windows (the zip can be unpacked to a specific folder, so don’t download the exe): [url]https://developer.android.com/sdk/index.html?hl=i#Other[/url].
Download the correct factory image and version for your Nexus: [url]https://developers.google.com/android/nexus/images[/url].
Download and install 7-zip so you can unzip the Nexus image for your device: [url=http://www.7-zip.org/download.html]Download[/url].
Make sure you have Java installed: [url]https://java.com/en/download/[/url].
Unzip the Android SDK tools file, then move the folder android-sdk-windows to C:\.
From the C:\android-sdk-windows\Tools folder, open android.bat (may just show android with a file type of batch). It may take some time, but it will load the Android Package Installer.
In the Android Package Installer interface, uncheck everything except:
Android SDK Platform-tools
Extras > Google USB Driver
Press the "Install" button in the Android Package Installer, then accept the license agreements and complete the download and installation.
Unpack these specific files from the Nexus image zip file to the platform-tools folder in C:\android-sdk-windows. Note: There are multiple tgz, tar, and zip files to unzip before you locate all of these necessary image files. Don’t worry if you don’t see the .img extension, it’s still there:
boot.img
bootloader (version info).img ← Note: this file name will be different depending on your device. Please make note of the exact file name.
cache.img
recovery.img
system.img
userdata.img
radio (version info).img - Note: some devices do not need a radio (Wi-Fi only devices). If you have it, please make note of the exact file name.
Press the Windows key + r, then type and run CMD in the box that appears.
Type cd C:\android-sdk-windows\platform-tools in the CMD box, then press enter.
Restart the device into the bootloader:
Power the tablet down completely.
Hold the volume down button while pressing the power button.
Connect the device to your computer.
In the CMD window, type fastboot devices to make sure your device is detected. If it isn’t detected:
Try a different USB cable.
Switch to a different USB port on the computer.
Remove/re-install drivers ([url=http://developer.android.com/tools/extras/oem-usb.html]OEM USB Drivers | Android Developers[/url]).
Try a different computer.
To unlock the bootloader so you can reinstall Android:
In the CMD window, type fastboot oem unlock
Use the volume button on the device to highlight Yes, then the power button to confirm your choice. Don’t worry if the device doesn’t respond right away - it can take a few minutes to initiate and complete the unlock process.
Once the bootloader is unlocked (Lock State - unlocked on the device bootloader screen), type the following commands to reinstall Android (please wait after each command until it shows Finished):
fastboot flash bootloader “bootloader [version info].img” ← Note: you can press your keyboard’s tab key twice after typing “bootloader, and Windows will auto-fill the rest file name for you.
fastboot reboot-bootloader
fastboot flash radio “radio [version info].img” ← Note: Step C is not necessary for Wi-Fi only devices. You can press the tab key after typing “radio, and Windows will auto-fill the rest of the file name for you.
fastboot flash system “system.img”
fastboot flash userdata “userdata.img”
fastboot flash boot “boot.img”
fastboot flash recovery “recovery.img”
fastboot format cache
fastboot reboot
Allow the device to finish the first time startup (which can take up to 20 minutes).
If you have any questions please feel free to reply back to this email.
Thanks,
Carlos
The Google Support Team
I find it disconcerting that Google's design doesn't allow for a simple restoration to a truly 'pure' OS build, but instead makes it much more tedious to remove carrier code tinkering (that could make it more awkward not only to update the OS, but also to switch carriers (e.g., what if a modified build for another carrier was activated onto T-Mobile - would T-Mobile's build incoroporating support for their proprietary VOIP deploy?).
Monex11111
