Will the Note 7 run Android 7.0 Nougat Out of the box??
Status
Not open for further replies.
I don't compare OTA to flashing images.
That's fine :p on a major OS update leaping base API versions I like to flash anyways and do a clean install, so it's all good to me either way. But yeah, definitely not as easy for all users.
marshmallow just began rolling out to most devices. No one is ever happy with the OS they have. After updating to Marshmallow I noticed nearly zero difference other than my icons. No performance changes. If anything, it's worse.
This guy's gets it I'm way way more interested in the new touch wiz it's looks hella nice the N version doesn't even have all the features I now have on my note5 and gs7 edge
Yeah and if history tells us anything we will not get Android N until March or April when the GS8 launches as this is typically when those updates go out since the newer model is out.
It also depends on carrier. I believe att note 5 was in June
Agreed which is sad basically you can expect a year almost which is why I like buying unlocked international versions my note 5 got marshmallow in February and another update in may.
Status
tsmtoolpro
