Will you root your Note8?
I don't know what rooting your phone is But I just bought the n8..And tried to opening the s health but it won't work because my phone is rooted .. I mean how was it rooted when it's completely sealed and boxed..when I first opened it !!
that most certainly shouldn't happen, is your phone snapdragon or exynos?
if exynos you could check if the OEM unlock toggle is ON in developer options, it shouldn't be but if it is then just switch it off and try again.
Rooting is pointless for me, all the features I want are included in the device right out of the box.
Rooting will come in useful after your contract is over and you want Android os upgrades and security patches. My old Note 3 is still running and is using 8.0.1.
This is true :D, Not everyone upgrades every year or 2, And when we have expensive devices that still work well, Replacing the battery and adding a new ROM is a good way to extent the lives, Too bad we lost removable batteries.
True there isnt really a need to root( I have the note 8,9) the 8 is rooted the 9 bo leaving it as is , but I do like having access to root files removing all that bo8at were that carrierr put in,also custom recovery is good and boot logos.... so all in all note9 is a great phone.... last year I had apple x phone ... and I was all about apple...just say I am no more longer a fapple... and I still have Macbook pro,iPad pro,iwatch etc.
I was able to root every phone I had for (too many) years with Verizon.
I'm on Verizon. So, no I won't root
I was on Verizon for 26 years. Verizon locks their bootloaders with milspec locks. They have all been defeatable and every phone I had with Verizon, from Droid RAZR through several iterations of Samsung Galaxies was successfully rooted. See if there is a version of SafeStrap & Chainfire's SuperSU for your phone model. SafeStrap works around the locked bootloader.
Re: I was able to root every phone I had for (too many) years with Verizon.
To root or not to root. I run apps that I've written & other security people have written that help in PENtesting, but require root access to the kernel. It depends on what you want out of your phone. I always root phones & tabs. su gives you admin privileges to the lowest directory level where you can root out (pun intended) & delete all of the bloatware your carrier & manufacturer use to waste storage, which you can reclaim for your own apps. You can run powerful programs like Titanium Pro, which does a thorough backup that includes all system files & apps, not just user stuff. You can use RCB (Root Call Blocker). Regular phone blockers just give you a pick up/hang up option. That's all a spam artist needs to add your phone to lists of "active" numbers - making the lists more valuable. RCB blocks the call before you get to the phone circuitry, telling spammers this is an out-of-service phone. Result: not on lists. I like TWRP recovery. There are, in fact, hundreds of apps that are desirable, but can't run on unrooted phones (try going to Play Store & type in "Root" or "Rooted" & see what your super-smart stock phone can't run). I use Samsungs routinely and, though I can replace the Touch-Wiz loader with dozens of custom ones, rooting gives you the ability to choose from hundreds of custom versions of Android, from plain vanilla to supernaturally powerful. My only problem is that I rooted my Note 8 when the security patch level was 3 & gave it to my wife. My new Note 8 has patch level 5 & the root exploit only works on patch levels 1, 2, & 3. Darn Samsung slipped code to defeat the exploit into patch levels 4 & 5. So, I'm stuck unless somebody develops a new exploit that can defeat their half-smart trick. This is almost as much a dealbreaker as Bixby is. I've disabled as much of it as I could, but to totally remove the bugger, I'll need su. I don't care about tripping Knox, as if I have a problem big enough to require warranty work (where you basically get back a refurb phone in place of your damaged one), I'll just use it as an opportunity to check out the new Google & LG models. If all you want is a fancy phone, don't root. If you NEED to run apps that require rooting, then root.
jonathanjude937
