Wireless Charge with magnetic plate?
I have used a magnet mount for a few years now. For the S8, I have to place it all the way on the bottom of the phone. I use a Caseology case with the soft back so on bumpy roads, it might rotate on the car mount. I have to use the full size rectangle plate but I can use the thinnest plate though.
I wireless charge at night too. I have Spigen cases that work too.
When the magnetic ring is placed this low on the back of the phone, will it still work with the magnetic car mount? Or is the phone then too top heavy for the magnetic mount to hold it securely?
I desperately want to make the magnetic ring, charging stand/pad, and magnetic car mount work together! Thanks!
I've had some success using the round plate and placing it about 1/4" from the bottom. The phone sits a little high on the mount, but it seems to be secure. In this location, mine is able to wirelessly charge.
I love wireless charge. I also love my magnetic car mount.
But I can't find a sweet spot for the plate that doesn't interfere with the wireless charge on the S8.
I'm using the Spigen Neo Hybrid Case with a Mountech AIRSNAP mount.
I'm thinking either try the Slim Fit case, or maybe a different plate of some kind.
Anyone have success with wireless charging and magnetic phone mount with this phone?
Grab one of these https://www.ipitaka.com/collections/magcase-for-samsung-galaxy-s8
Yeah I have the same setup, but like what many has said need to be at the bottom portion of the phone.
It will feel less secure on the car mount but general should hold nicely
Hello people!
Did anybody try Pitaka Aramid Fiber case? I'm curious as it seems a good solution to the sam problem i'm havin (as you have): magnetic mount and wireless charging. It's supposed to have metal inside the already thin layers that go around the wireless charging plate in your S8, iphone or whatever.
This can be coupled with any wireless magnetic mounts (the round types) found online and it works.
What's your oppinion?
I'm using the Spigen Neo Hybrid Case with a [URL="https://www.amazon.com/Mountek-Smartphones-Phablets-Frustration-Free-Packaging/dp/B018M8L7Z8?tag=hawk-future-20&ascsubtag=UUacUvbUpU6700287]Mountech AIRSNAP[/URL] mount.
Yes there is a solution..I have a note 9. I bought the thin stick on magantic plate thingy that sticks to the back of the phone. I placed it high (or low) enough to allow wireless charging. It works great
This works for me with Note 9, TYLT wireless charger, Neo Hybrid case and Spigen car mount.
Miserydhala
