Wireless charger
Samsung says Wired charging compatible with QC2.0 and Wireless charging compatible with WPC and PMA - but all Zens says is 15 Watts, so there's no way to tell if the charger is compatible or not. Some reviews say yes, some say no.
Assuming that Samsung is being accurate, you want WPC or PMA wireless and QC 2,0 or better wired (QC 3 and QC 4 will also work). But Zens just says "Qi", and that's not necessarily QC anything, and they say nothing about their wireless spec.
Ridiculous all these different standards. Should be one for all phones.
Good luck figuring it out.
I've been using the Anker Wireless charging pad with my S10, and it's been working great. It provides 10W of wireless charging power to the S10 and charges amazingly quick. I'm using a Quick Charge 3.0 adapter to power it. Very nice pad with a flat rubber surface to prevent the S10 from sliding. It also has a very small indicator light.
mostafamu
