Wireless Charging issues (not charging)
Thanks, I did find a video on YouTube, the one he had the fast charging and fast charging was under battery settings. Mine has fast charging but not fast wireless charging there.
Have you ever put your device on a fast wireless charger?
In previous models, the option only showed up in the menu AFTER you had first put it on a fast wireless charger.
I don't think the op has since it was stated that she has one coming
No I have not. I have one ordered. I'll wait and see till it comes in. Thanks
This might sound like a strange question but are you putting the phone on the wireless charger horizontally or vertically? I have the Samsung wireless charger that I can lay down or prop up. I prop it up lay it down horizontal. That works best for me. When I lay it vertical, I have a hard time trying to get it to work.
Not only horizontally or vertically - the coils in the phone have to be aligned with the coils in the charger. Sometimes moving the phone around a bit will show you the edges of the active charging area. Putting the phone down outside that area, while it might look as if it's on the charging pad, won't charge it.
Mine wasn't fast Wireless charging, but I was using the newer "super fast charging" brick that shipped with the phone. When I switched to the older "fast charging" brick, it worked. So it also depends on what charger your using. It also didn't fast wireless charge with my pixel charger.
If you were trying to use the Samsung fast wireless charger, it's pretty picky about which bricks you use.
Goday73
