Wireless charging pad for s5 is it compatible for charging s6?
  • Start date Start date
A
AC Question
just wanted to know before il buy the wireless charging pad for s5, can be also used for s6?
Re: wireless charging pad for s5 is it compatible for charging s6?
Welcome to the forums. I would think that it would work. If you are getting it from say, Amazon, it should be really easy to return if it doesn't.
