Wireless Storage on the LG G2
I have the Sprint model and it appears that this feature is no longer available, post Lollipop update. At least I haven't been able to locate it.
Mine is working fine with lollipop (on verizon though). Thank you for this thread!
Is there any way to make the phone use the same address every time I turn wireless storage back on? I don't like leaving it on all of the time, but when I turn it on to use it, I have to edit the shortcut on my laptop to have the new address.
I was having trouble setting up wireless storage on my LG Volt, so I searched and found this thread . . . and the simple statement about "entering the IP address into the [Windows] Explorer" went <SNAP!>: The Help on the Android for doing this said to enter the same into my BROWSER'S address field!! The latter does not work, giving the "cannot connect" message, but entering it instead into (My Computer) Explorer address makes it all work fine!
Instead of using the IP address, use the device name--e.g., on my Windows XP it's
\\LG_Volt\LG_Volt
I think that will always be the same, no matter what IP address the router assigns when you log on.
gmcbride
