With android 7 wireless charging is now hit and miss.
mikefiori1
Active member
Oct 17, 2013
38
For the last two years, every morning the phone would be fully charged using a wireless charging pad. Maybe 4 or 5 times over 2 years it would be close but not fully charged. With android 7, 8 out of 10 days it's not even close. If a txt or email comes in while charging it seems it just stops. Have to pick up the phone and reestablish the wireless connection for it to start. How they could screw up a key feature like this is beyond me.
Sorry you're having charging problems. My S8+ actually charges a little faster, but others have also noted disconnected charging, there are some good threads here on the forum you might want to read over. I personally don't let my phone charge any longer than it takes to reach 100%. You also may have better luck with the newer wireless chargers as others have posted improved performance with those. Good luck with the phone.
Make sure its sitting solidly against it. I've caught mine raised up slightly off the charger. Mine is the stand, and sometimes I don't quite get the bottom set flush to the stand, and that seems to cause delays and pauses sometimes. Also, try switching your cable and/or adapter, it may not be supplying sufficient power to your wireless charger.
Disable vibrations? Maybe it's sliding when you get a message or a call.
wwest
