Won't boot! Help!
Quinpin
22
I just rooted my phone and tried to install CyanogenMod 7. When I went to restart into recovery my phone got stuck on the white HTC screen. Is there anything I can do?
Pull the battery... put it back in... Press and Hold the Volume Down button, then with that held down press and hold the Power button... this will boot it up to the hBoot screen... select Recovery... and reload the ROM.
Reminder... Double check the MD5 Sum code of the ROM file you downloaded before trying to install it on your device.
AirlinesTravels
