Xoom and n64oid?
Wait a second, I just got the Wiimote, I should get another remote to attach to that for even better gaming? - What is the classic remote? - Like the N64 controller itself?
yea i would really like clarification on this. can someone spell out the actual controllers you need and what each one you are listing is with a link to them to help others?
edit: google is my best friend
So thefredelement, i am assuming this is what they are doing.
the left controller = wii classic controller
the right controller = wiimote
then they download the wiimote app and sync the wiimote to it and attached to the wiimote is the wii classic controller. Which will allow for EPIC gaming
Reactions: 2CupsWithString
Awesome, thank you.
I see on Amazon there is the Wii classic and classic pro, I wonder if the classic pro would work well with playstation games? Anyone have this combo?
anyone using any other bluetooth controllers for n64oid? doesnt seem like the ps3's will ever work, what about another third party controller? I just hate having to carry around and plug in the wii remote to make the classic work.
wii classic pro controller is not supported by the wiimote controller app
Ah, I already ordered it. I see a few different apps though, maybe I'll get lucky?
Does it not work at all that you know of - or just the extra buttons or something?
Just fyi.. cheaper aftermarket wii motes don't work consistently. Found out the hard way when I tried to save a few bucks. Just got with the wii motel from Nintendo and the classic controller [regular].
Sent from my Xoom using Tapatalk
Have you tested this with the Xoom and n64oid? If so, how is that controller holding up?
Ive tested this and works perfectly. Ive had the Datel Retro Wireless controller since ive own the DX.
The early release of the N64 was laggy yes but since after the update its runs so smooth. Going to Try 2 Players Goldeneye 007 on the weekend :cool:
Be sure to report back on the multiplayer
I know it's been months since the last response, but has anyone attempted multiplayer with Goldeneye. If so, what is your controller setup (controller type and program used to run it). Thanks!
Asad
